Clutch has no pressure
Old Jun 29, 2022 | 05:05 PM
MckenzieR's Avatar
Default Clutch has no pressure
So my 94 del sol has recently had a brand new slave and master installed by my boyfriend. Everything seems to have been done correctly and we bled the line very thoroughly. The clutch gains the smallest bit of pressure and will not spring up
. If anyone has any advice on if we may have bought a bad master(second time replacing in 2 months we thought it was a bad part the first time after replacing it) otherwise maybe a leak in the line which we did try to check for, any advice would be great.
Old Jun 29, 2022 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Clutch has no pressure
Did you "bench bleed" the clutch master cylinder BEFORE installing it in the car ?
Daniel Nault
Honda Civic (2001 - 2005)
Oct 29, 2015 07:28 PM
ImmaculateDelSol
Jun 11, 2009 06:43 AM
macfadyen
Sep 7, 2006 12:00 PM
SilverDc2
Jan 16, 2005 10:04 PM
ILOVEGIRLS
Mar 27, 2003 01:14 AM
