Classic Hondas All Pre-1988 Hondas.
'77 Civic 1200 water valve
Old Jun 24, 2022 | 01:35 PM
oldbikesrcool's Avatar
Default '77 Civic 1200 water valve
So, my heater control valve is stuck in the "most heat" position. OEM replacement obviously not available. Looking for a drop-in replacement has me seeing cross-eyed.
I was told by an old radiator shop guy that he kind of remembered either adapting a later version Civic heater control valve or he used a similar year Fiat unit (124?).
Does anyone know a replacement model "water valve" that's a known solution in 1st gen Civics?
Old Jul 3, 2022 | 04:52 AM
XKAES's Avatar
Default Re: '77 Civic 1200 water valve
Do you mean #7 in this diagram? If it is, your problem might be that the cable is broken or stuck -- and needs replacement/adjustment. If that is not the case, you can remove the valve and soak it in CLR, etc. That might "unstick" it. You can also search EBAY, junkyards for a replacement. These don't tend to wear out -- they just can get stuck. The valve will be the same on the CVCC and Station Wagon Civic for any year from 1994 to 1979. I have an entire heater core and fan that I hope to get posted on EBAY this week.
https://www.cmsnl.com/honda-civic-19...l#.YsGQK4TMJgw
Old Jul 10, 2022 | 08:33 AM
Unfortunately, the diagram link depicting #7 didn't come up; 'just the CMSL home page. However, yes, it's the heater control valve (Honda manual calls it the "water valve").
Cabling and controls all confirmed good and it is indeed the valve that is the problem. I like the idea of a CLR soak-n-work to hopefully free it off.
Honda lists different part numbers for the later generation ('79 - '94) "water valves" so am assuming perhaps a fit/form revision change? Or not...certainly worth a look-see.
Thanks and cheers!!
Old Jul 10, 2022 | 11:50 AM
don foreman's Avatar
Its a common leak point too. I know there has been a lot of people looking for good parts as they age. Soaking in CLR may make it leak, but not much choice at this point.
Old Jul 10, 2022 | 01:44 PM
XKAES's Avatar
Sorry. I guess a COPY/PASTE error. Try this link for the diagram:
https://www.cmsnl.com/honda-civic-19...l#.YstHr4TMJgy
This calls it the "water valve" and is a good diagram of the two connections & clamps, and one (or probably two) bolts holding it in place.
The biggest problem might be getting it out and back in -- and old, brittle hoses.
kevinyo01
Nov 21, 2016 06:05 AM
thewrai6th
Mar 10, 2016 04:24 PM
fallmartin
Dec 2, 2008 05:01 PM
fastrc2
Jun 20, 2008 02:58 PM
zgrimes
Oct 18, 2001 05:36 PM
