What do you think I should be running?
Curious if anyone could help me out.
I've got a 99 Civic with a turbo LSV in it. Its dyno tuned at 344whp and 226wtq. It weighs 2700lbs with me and a full tank of gas. The best time I can get on Dragy is 13.60 @ 96.53mph
60ft-2.39
330ft-6.12
1/8th-8.97 @ 87.90
1000ft 11.41 @99.67
1/4- 13.60 @ 96.53
Is it my 60ft time that needs to get better? I truly believe reading a lot of old forums on here that 340whp at 2700 lbs should be a lot quicker then 13.60.
Thanks! First post so please dont roast me. [img]file:///C:/Users/wilma/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/img]
60ft-2.39
330ft-6.12
1/8th-8.97 @ 87.90
1000ft 11.41 @99.67
1/4- 13.60 @ 96.53
Hi Ryan,
I would venture to guess you're on 15" wheels and tires, correct? Going to a 13" slick will be night and day. I tried to make my 15 inch wheels with 205/50/15 200tw tires work for a while, but after having a conversation with Brent from PFI, his first advice was going to a bias ply tire. He said, and I validated, that making the 15" setup work is very difficult. By making the switch, all my wheel hop was immediately gone, and my 60' went from a 2.2 to a 1.9, on the first pass.
Make sure your clutch can take the slipping that is necessary. I'm at ~450hp on gate, and CC Stage 4 has been fantastic to me.
Good luck!
Good luck!
Hi Ryan,
Good luck!
Good luck!
Nice, that clutch should take the slipping no problem. Just gotta try some bias ply's now, the soft sidewall is a must. I would guess your car should be in the mid 11's.
hondamark35
38
Jun 25, 2007 04:11 PM
