Maintenance Light. How do you turn it off?
Old Nov 17, 2002 | 07:24 PM
AB16A2T's Avatar
Default Maintenance Light. How do you turn it off?
This is in a '98 Accord LX, Auto. As the topic states. Thank you.
Old Nov 17, 2002 | 07:35 PM
gogeeta13's Avatar
Default Re: Maintenance Light. How do you turn it off? (AresB18C1Turbo)
stick your key into the rectangle cut out in your guage bezel so that you push that little plastic thing.
Old Nov 17, 2002 | 07:44 PM
AB16A2T's Avatar
Default Re: Maintenance Light. How do you turn it off? (gogeeta13)
I looked no rectangle cut out in my guage bezel...
Old Nov 17, 2002 | 09:30 PM
Razor's Avatar
no no no, thats for 5th and 4th gens. for 6th gens, turn the key to where the lights on the cluster turn on. then hold down the trip/reset button for like 10 seconds, just to be safe, hold it for 15 seconds. then let go. turn key to complete off position. next time you turn on your car the maintanance required light will be off.
pretty easy eh?
Old Nov 18, 2002 | 08:49 AM
archangel7335's Avatar
Default Re: Maintenance Light. How do you turn it off? (Razor)
Good deal, I actually had that question myself. My 2000 EXVL just turned over 61,000 miles and it went off, done a error code check and it came up with nothing so I figured it was preset to get me in for emissions or the timing belt. Just out of curiosity, (this is my first DOHC car) how long would you go on changing the timing belt on it considering that I autocross with it? Thanks for your time.
Old Nov 18, 2002 | 09:45 AM
GTPdee's Avatar
Thanks, I had the same problem w/ my wife's '94. I was just too afraid to push that thing, didn't know what it would do.
Dimitrios aka GTPdee
Old Nov 18, 2002 | 09:49 AM
AB16A2T's Avatar
Cool, thanks Razor.
Old Nov 18, 2002 | 09:55 AM
AB16A2T's Avatar
Nope Nope, that one didn't work either, I held it for 10 seconds, then I tried 15, and then 20. Didn't work, anyone else?
Old Nov 18, 2002 | 10:02 AM
Stew Pidasso's Avatar
What Razor said was correct.You must turn the car ignition to the run position (don't start it). Hold it in for 10 seconds, then turn the key off. Turn it back on and start the car...done
Old Nov 18, 2002 | 10:14 AM
AB16A2T's Avatar
Default Re: Maintenance Light. How do you turn it off? (Stew Pidasso)
I tried that, but it didn't work. I put it into the run position, the second click, first click for the radio second click to start all the electronics. I held it down and it didn't go away.
Old Nov 18, 2002 | 11:41 AM
I got it to work. I held in the reset until the maint. light went off when I had the electronics engaged. Had to try it a couple of times but got it to work. Might just have to play with it a little bit.
Old Nov 18, 2002 | 11:44 AM
AB16A2T's Avatar
Default Re: Maintenance Light. How do you turn it off? (archangel7335)
How long did you have to wait?
Old Nov 18, 2002 | 02:59 PM
I dunno...few seconds. If I remember what I did correctly the time I got it to work; I held in the trip reset and then turned the key to the correct position then watched the maint. light come on and then released it when it went out.
Old Nov 18, 2002 | 10:11 PM
iam7head's Avatar
DOHC??? 00 acord i4? v6?
Old Nov 18, 2002 | 11:46 PM
AB16A2T's Avatar
Default Re: Maintenance Light. How do you turn it off? (iam7head)
SOHC. VTEC 2.3 Inline 4. Not sure of the engine code, F23..
Old Nov 19, 2002 | 08:19 AM
Its the V6. I was actually thinking about going with a I4 when I was originally looking for a car due to the normally small space between the firewall and the motor on FF V6's but when I saw that I had plenty of room to play I was sold on it...lol. Gotta love Honda. Oh also...can someone tell me how to change my avatiar on here. I have looked around and couldnt find it. Maybe just not looking in the right place. Thanks.
Old Nov 19, 2002 | 08:24 AM
After your trial period is over click on the my profile link in the upper right. You will see another link to change your avatar.
Old Nov 19, 2002 | 12:18 PM
cool, thanks
burntkookie
Acura TL, RL & ZDX
Jul 2, 2010 01:07 PM
lmike6453
Jul 18, 2007 04:24 PM
Reddog
Nov 5, 2004 04:50 PM
SHORT AND STACKED
Feb 27, 2004 07:36 PM
abeaujuin
Aug 7, 2003 01:29 PM
