I see a drop of oil here sometimes, what is the problem?
Old Jun 17, 2022 | 03:54 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Default I see a drop of oil here sometimes, what is the problem?
I see a drop of oil here sometimes, what is the problem? Where is the oil coming from? How do I make it stop?
Old Jun 17, 2022 | 04:41 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: I see a drop of oil here sometimes, what is the problem?
Rear main seal. Change it.
Old Jun 18, 2022 | 03:01 AM
moosemaster's Avatar
Definitely check from the top down. Could be your valve cover. I had a little tiny drip what looked like was coming from my trans was a **** feel-pro valve cover gasket. Get the oem one from Honda with a few hits from Honda bond. Would be cool since rear main seals are A pain In the **** to get to
Old Jun 18, 2022 | 08:08 AM
Ryanthegreat1's Avatar
At this age if you are going after the rear main it would probably be wise to have a repair sleeve on hand. Likely to find the crank has grooves in it where the seal rides.
Old Jun 18, 2022 | 08:07 PM
Austin mccool's Avatar
Could be the o ring on the distributor and if any one knows why a 91 brand new distributor plugs and plug wires won't fire on 3 and 4 let me kno pls
Old Jun 18, 2022 | 08:50 PM
Do you have any idea on why a brand new distributor in my sedan is not firing on the number 3 and 4 points and had to be ran backwards for tge car to start
Old Jun 18, 2022 | 10:09 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Start your own thread.
Old Jun 19, 2022 | 02:01 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Is there a way to rule out the possibility that this is coming from the transmission? Do they make some sort of dye that could be added to either the engine oil or the transmission oil?
Old Jun 19, 2022 | 03:35 PM
Not to my knowledge. You could drain your tranny oil and measure what comes out and measure how much goes in? Might not be super accurate though.
SPRLude
Apr 6, 2006 08:18 PM
eksleeper
Jun 22, 2005 08:31 AM
civichtchback91
Jul 2, 2004 02:45 PM
SIK IN DA HED
Jun 23, 2001 07:57 PM
