Engn. Coolant Temp. Sensor Code 6
hey every1
I replaced my ECT sensor yesterday hoping to resolve a code 6. After I replaced it I went ahead and reset the ECU (unplug battery with ecu and hazard fuse?) now the CEL is stuck on reading no codes, but it still sounds like a fuel related issue.
Fuel pump read resistance and my injector connections are getting power, just not sending enough fuel? i’m not sure.
any help is greatly appreciated,
best, VE
best, VE
Check the wiring to the ECT sensor plug. Use a scanner to clear the code, you can buy the cheap $20 ones from Harbor freight or some Walmart locations.
coffin on wheels
Feb 22, 2007 11:22 AM
