Clicking clutch pedal driving me crazy
There’s a very annoying “pop” “click” sound coming from the clutch pedal about 1/2” before it reaches the floor when pressed.
It’s the pedal itself and nothing else major down the line.If I remove the pin that goes through the pedal and clutch MC and put it back the noise goes away but ALWAYS returns 2-3 days later. It’s the weirdest thing.
The master cylinder was replaced a year ago with an Exedy brand but the clicking did not start when it was replaced, developed maybe 3 months after. So maybe it could be that too? Just very strange I can get it to stop producing the sound if I fiddle with that pin. Also tried lubricating all springs, movable parts, and even where the rod goes into the MC.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Since Honda no longer has the u-shaped bushing available try and grease up that area (where the N-shape of the clutch return spring connects to the U-shape area on the clutch pedal) with some Urea grease, Lucas oil sells it under their "Green" grease heavy duty. Honda has a backorder situation with the Urea grease right now.
yup I have ideas of what it is.. It's not the master cylinder, went through this before.. It's the return/assist spring on the clutch pedal. The N-shaped part of the spring goes into a plastic u-shaped bushing. When the bushing gets dry or cracks under usage it allows the spring to shift and you hear that "click". That pin you're messing with only needs to be adjusted for distance, but take a look and see the return spring on the pedal is right next door!
yes it's the area you highlighted in red, exactly! See how close it is to the MC pin you highlighted in yellow?! Yup right next door, probably why you thought the noise was coming from the MC pin..
Nice I’ll take another look. I had originally lubricated that a while back when chasing the noise but used synthetic suspension grease that I had lying around at the time
hey no problem.. .Might not have been thick enough grease to put up with the constant back-n-forth motion of the clutch pedal, probably why it was quiet for awhile. That green Urea grease is very sticky and thick! Honda doesn't have any in stock that's why I mentioned the Lucas oil Heavy-Duty grease (green) it is also a Urea grease.
Wondering if it could be something else causing it for me
both plastic pieces were replaced and used the urea grease to lube it up. no noises anymore.. did you grease it up and the noise still came back? Look up in there, I had used an inspection camera to get up there.. see if the plastic pieces are cracked in half.
I’ll double check to see if it’s cracked but it didn’t look to be. Where were you able to find a replacement? Does the entire pedal assembly need to come out to replace it?
Double checked and it’s not cracked. I reduced the clutch pedal free play a bit and the clicking noise seems to be gone now, but I’m wondering if there should be more free play?
I’ve included a video trying to measure, seems to be about 1/2” free play now before it was about 3/4 to an 1”. Clutch grabs with pedal higher than before adjustment.
Curious how much pedal free play does your car have?
But the way it sounds you don't need to replace them at all.. I bet what was happening was the free play being out of spec/adjustment the angle was greater on the pedal causing the plastic bushings or the spring to shift and that would be the clicking you heard. Now that it's aligned/adjusted the spring is more angled straight on into the bushings and no noise! With my clutch and adjustment the clutch engages at the 1/2 way point of the pedal travel.. I bet that's about where yours is engaging instead of towards the floor.. For me, that's where I think it should be.
I'd say you fixed it! See how that goes for awhile, I bet it'll be just fine now! good news!
Wanted to wait enough time before posting to make sure, but glad to say the clicking seems gone for good. It was for sure the free play adjustment.
Hope this helps someone who may be experiencing same issue as something to check for, and @oneheadlight appreciate the help and info!
So guess I spoke too soon lol the damn clicking noise has once again returned. Albeit this has been the longest it’s been quiet. Really not sure why it keeps returning
But you're right, why it went away for so long and came back.. mine wasn't like that, ok it would click every 2nd push of the clutch pedal, but it didn't disappear for weeks.
z06eateR
Feb 12, 2009 08:09 AM
