02 sensor replacement seems not possible
Old Jun 10, 2022 | 02:13 PM
KMock79's Avatar
Default 02 sensor replacement seems not possible
Trying to put in a new o2 sensor. Got a o2 wrench, no room to move even a single byte. A singular manifold bolt stripped so can't get that off rn either. Kind of screwed it seems
Old Jun 10, 2022 | 05:39 PM
Maxcapacity's Avatar
Default Re: 02 sensor replacement seems not possible
If you ain't got room, make room.. easy to remove stuff. Did you get a actual wrench style or something handy dandy like the crow foot style?
Here's what I use in tight spaces.
If it's really stuck when you get at it, try something like Releasall lube or bust out a propane torch and get the threaded portion nice and hot, heat will be your friend getting it out. Just make sure the flame stays clear of anything non metal!
dohcvtecpower
May 7, 2009 07:41 PM
boostinh22
Dec 8, 2005 11:33 PM
ABK
May 27, 2004 08:31 PM
CivicBoi
Mar 30, 2002 12:07 PM
