Mystery Connector
Old Jun 4, 2022 | 10:16 AM
Lacivicowner's Avatar
Default Mystery Connector
2000 civic ex I’ve had since new. Been a great little car.
i was doing some maintenance and came a cross a post about some model years having a cabin air filter. Mine does not. But I vacuumed the compartment out etc. When I went to put it all back I noticed a length of wire with a blue connector. Now it had a been a week from the point I started to the point of putting everything back. I don’t recal disconnecting it from anything and can’t find anything to connect it to. I’ve searched the web, and even looked through some YouTube vids to see if I would catch a glimpse of it. The car runs fine, everything functions. So I’m turning to you all. It comes out through the floor, passenger side. And has a fairly long wire. Any help will be appreciated. Thank you in advance.
Richard
Old Jun 4, 2022 | 10:27 AM
loginlogin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Mystery Connector
Try to check what is on the other end of this cable.
Old Jun 4, 2022 | 09:36 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It is likely the connector from a Honda accessory CD changer.
Old Jun 5, 2022 | 11:23 AM
in reply to both login login and tech8. First of all thank you both.
Tech8, as soon as I read your reply I remembered that old Cartridge CD changer in the trunk. I removed it years ago when I installed a newer radio.
and yes indeed loginlogin following the wires back led me to the trunk.
thank you both again for your help. I can install the last bit of trim back now. I also labeled it for next time!
Mystery Solved!
Old Jun 6, 2022 | 01:58 AM
Chrisfrom1986's Avatar
@Lacivicowner do you still have the cd changer?
Old Jun 6, 2022 | 06:55 AM
Unfortunately no. I gave it to a friend.
nedriv49
Aug 9, 2020 12:35 PM
taylorgang
Oct 18, 2011 07:10 AM
hondastrtracr
Mar 8, 2008 09:31 AM
mouseghb
Jun 4, 2005 10:19 PM
Battle Mike
Nov 18, 2003 05:09 PM
