2000 honda accord f23a4 ulev running issues
Old Jun 3, 2022 | 05:41 AM
Biggie!3's Avatar
Default 2000 honda accord f23a4 ulev running issues
Good morning all i have a 2000 honda accord f23a4 5 speed that was throwing a 1166 and 1167 as well as 302,301,300,303,304 and 1399pd. i have changed the plugs cap rotor wires and plugs. i just replaced the upstream o2 sensor and have similar running issues. I removved batt cable and only codes 301,302,300 and 1399pd i have been running fuel treatment thru the tank every other fill up. It sounds like the unit has a miss. I did pull the plug wires and found that cyl 2 has spark but doesnt change the sound or performance of the engine. I am getting ready to check compression but it leads me to believe the injector is an issue but looking to find some ideas of what may be a common issue on these. it seems to look like plugs may be showing a lil lean. Love my new lil daily driver but not a fan of these ULEV
Old Jun 8, 2022 | 11:15 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2000 honda accord f23a4 ulev running issues
When was the last time the valves adjustment was checked or done? They should be checked every 30Kmiles.
Exhaust side is usually tight, this will cause a lean misfire from the valves hanging open.
Old Jun 9, 2022 | 05:24 AM
Biggie!3's Avatar
I HAVENT DONE THAT YET GOOD SUGGESTION THANK YOU DIDNT THINK OF THEM CLOSING UP GETTING TIGHT ILL CHECK THAT OUT
beberle
Apr 15, 2016 03:04 AM
rimestime
Jun 6, 2015 05:13 AM
Aadavis94
22
Mar 19, 2015 07:47 AM
sdmtkm
Feb 16, 2014 04:29 PM
CD5B2
Jan 19, 2013 09:53 PM
