need help reviving a 2000 accord
this darn accord has been sitting in my driveway for a year now and i just started my attempt to get it running. The car cranks has power but doesnt turn over. Ive changed plugs, wires, dizzy cap/rotor, battery, all fluids, and timing belt. its a 2000 accord automatic. What should I do next?
Re: need help reviving a 2000 accord
there is spark and compression ran 190. 190. 200. 190
are these numbers acceptable? its a 4 cylinder . sprayed carb cleaner and still no luck.
Compression looks good.
Are you sure that the plug wires are connected in
the right order?
Could the timing be a tooth off?
When you sprayed carb cleaner while cranking
did you use enough to make the plugs wet?
the right order?
Id just check a few things. Since its getting spark check for fuel get someone to crank while spraying a little bit of carb cleaner or starting fluid. Id also recheck the timing marks and make sure they line up.
I would also highly recommend just getting a scan tool and hooking it up. Just to see if there are any codes.
fitbkeco
10
03-02-2013 02:15 AM
sivikvtec
10-20-2009 05:59 AM
