Chipped p28 to s300
So I recently bought a b16 swapped 1992 EG with a chipped SST p28 ecu. I want to convert it over to Hondata for remote tuning since I’d have to trailer the car 4 hours just to get it tuned. I’d like to get a base tune and then drive it to get dyno tuned but I have to convert the ecu first. Do I just undo everything from the chip install and install hondata normally? I’m pretty sure there’s a few capacitors that were added as well and the chip. The jumper is also connected so it’s running the chipped map.
Swap out the 28-pin chip socket with the male pins so that the S300 board can be installed over them... and don't forget to install the 4-pin male header in the datalog location on the P28 board. All of the other "Chipped" components are the same as needed for the S300... so you are good.
