Afr being crazy
Old May 30, 2022 | 06:29 PM
vaulko's Avatar
Default Afr being crazy
I have an ef with a minime swap in it, zc block, y8 head, z6 intake.
I’ve installed an arm Wideband cause it’s such a weird build I wanted to monitor stuff.
I used the bung from the stock 02 which is vertical on top of the exhaust between firewall and oil pan.
When I start the car the gauge goes crazy bouncing all over the place from 13 all the way to 18. It typically fluctuates between 14-17 and sometimes pegs lean
my idle surges. Idk if that would affect the afr that much or what’s the issue is it really that lean? As in dangerous to drive? Or could it be a sensor issue or wiring issue?
I pulled the sensor and smothered it with a carb cleaner rag and it pegged it all the way rich….
just not sure what to do or where to go from here. I have so many hrs into trying to get this running right I’m so overwhelmed
Old Jun 2, 2022 | 01:27 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Afr being crazy
what type of Wideband? That location and "angle" isn't ideal for a wideband.
Old Jun 2, 2022 | 03:46 PM
Maxcapacity's Avatar
You can damage your sensor cleaning it. They are not meant to be cleaned. If it a old unit, my autometer wideband pamphlet mentioned if the reading is acting up, most likely the sensor needs to be replaced or if yours is too far away then that might cause a issue. The sensor placement should fairly close to the head, I think within 18" or so..
Old Jun 2, 2022 | 07:02 PM
NVturbo's Avatar
O.G. triple O.G.
^^^ agreed. Mine is mounted right on the DP, between the radiator fan and block.
enzo1200
Apr 6, 2015 03:29 PM
hifi_civic
Jun 10, 2005 06:24 AM
Swifty
Mar 12, 2005 06:57 AM
EGbeater
Nov 21, 2003 07:12 AM
