Assistance needed: L15B 2020 Civic has wastegate codes after eBay replacements
Old May 26, 2022 | 04:36 PM
van1chka's Avatar
Default Assistance needed: L15B 2020 Civic has wastegate codes after eBay replacements
Hello everyone, i have problem with civic 1.5 turbo. I changed whole turbo assembly, bought on ebay, like new condition. When i installed, everything was perfect, no cel no lights. After some drive, i got cel, 2 codes. One is p003a : wastegate not learned and second p2563 ewg lift sensor out of range. When i erase code, i drive wirhout issue, when i stop vehicle and statt again, gives me the same codes. Did anyone have the same issue?
Old May 27, 2022 | 05:12 PM
highschooler's Avatar
Default re: Assistance needed: L15B 2020 Civic has wastegate codes after eBay replacements
First of all I’m assuming it’s a 2016-2021 Civic model- the L15 engine?
Did you replace your turbo with one similar to stock, or was it larger?
Does the new turbo have an internal wastegate inside of the turbo, or no wastegate inside the turbo?
Do you have Hondata, Kpro, or some other tuning software?
I haven’t had that issue, but those questions should help narrow down the issue. You might want to ask Hondata or a similar company if their product could solve those issues.
Old May 27, 2022 | 06:07 PM
van1chka's Avatar
i bought car with front end damage, and housing was cracked little bit. Bought whole turbo assembly and now it says wastegate range over learnt limit. I got autel and 2020 civic 1.5 exl
Old May 28, 2022 | 07:50 AM
You’ll probably have to calibrate the wastegate.
https://www.civicx.com/forum/threads...ctuator.65989/
This is for the Civic Type R, but supposedly it’s the same process:
https://www.full-race.com/articles/h...or-calibration
Check out www.civicx.com for more information or search “civic 1.5t wastegate calibration”
My_EFsedan
Nov 29, 2011 10:33 PM
jasony0630
May 5, 2008 06:44 AM
vestalfootball72
Feb 19, 2007 01:33 PM
b16ahybrid
Dec 23, 2002 09:27 AM
