Automatic to 6 speed manual in FWD Element
So I have an 04 automatic 2WD. I am planning on swapping to a 6 speed manual transmission. But one thing I am not clear on is do I have to use an Element 5 speed transmission and add the 6th gear like here (https://www.elementownersclub.com/th...s-parts.25635/) Or is that only required for the AWD Elements? Could I instead just get the box from a 7th/8th/9th gen Civic Si or TSX?
It sounds like I would have the same issue with RSX and Civic Si boxes. Is there any reason I couldn't fab mounting brackets for one of those boxes rather then buying a Element 5 speed and then buying all the parts needed to fit 6 speeds into the gearbox?
Dan_Bon
Jun 20, 2021 04:23 PM
Kirt Thelander
Acura TL, RL & ZDX
Nov 16, 2018 10:38 AM
