Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Change suspension to lift 2011 Accord without spacers
Old May 18, 2022 | 11:41 AM
harrierpilot's Avatar
Default Change suspension to lift 2011 Accord without spacers
Does anyone know a way to lift the car from the 5.5-inch stock clearance to roughly 7.5-inch without using spacers? I can't seem to find any struts/springs that raise it and most people want to lower their cars. The only possible exception involves adjustable compressed air, which I don't understand. There already isn't a ton of down travel in the original struts so I'm not a huge fan of using spacers. I need to not high center after 4 inches of snowfall while in parking lots and some additional clearance for light off-road to get to trailheads for hiking. I'm not doing the lift for the looks.
As another possible (partial) solution is if a larger tire could fit on the standard rims? I'm wondering if I can get an extra half-inch changing from 225/50R/17 to 225/55R/17 tires (which would increase the ride height 1.1cm total).
The car is supposed to have 5.5 inches of clearance and mine appears to have 5.25 while parked. It still has the original suspension.
Old May 18, 2022 | 12:22 PM
Ryanthegreat1's Avatar
Default Re: Change suspension to lift 2011 Accord without spacers
Put crosstour suspension under it?
Old May 18, 2022 | 01:44 PM
I could see how using Crosstour parts might work. I'm not sure what matters in order to figure that out but here are some links to the parts for both my car and the 2011 Crosstour for those of you smarter than I.
links
Accord front: 51610-TA5-A32 (or A22) https://www.hondapartsonline.net/oem...w0LWdhcw%3D%3D
Accord rear: 51610-TA5-A71 https://www.hondapartsonline.net/oem...ItNGwtbDQtZ2Fz
Crosstour front: 51610-TP6-A04 https://www.hondapartsonline.net/oem...bC12Ni1nYXM%3D
Crosstour rear: 51610-TP6-A04 https://www.hondapartsonline.net/oem...Y2LWdhcw%3D%3D
Pretty sure there are issues with this accuracy though as the Crosstour's front and back items are listed as the same part number but have different pictures. Some of the mounting parts between the two areas are the same but not all of them. Not sure which parts matter in order to be compatible. If this worked, I'm not sure how I'd know the height difference until after installation (assuming that's possible).
hugebob
Oct 11, 2011 11:19 AM
MaxWedge426
Nov 15, 2010 05:54 AM
subhu1030
Sep 22, 2007 01:50 PM
CBL9
Dec 7, 2006 07:10 AM
jdefranc938
Feb 5, 2005 05:06 AM
