What parts do I exactly need to rebuild my H22a4 with rod knock?
Old May 10, 2022 | 03:56 PM
kilawna's Avatar
Default What parts do I exactly need to rebuild my H22a4 with rod knock?
Hi everyone! I’m a new Honda prelude owner and I bought a fifth gen and it has rod knock. I’m trying to price out rebuilding the one with rod knock or buying a replacement and do some “up keep” to that one?
I got a quote from a machinist and I’m just trying to figure out all the parts I’ll need just so I can compare the two in price. I’ve tried and tried to google to figure out all I need but there is just so many different answers from all over the place.
all help is thanked!
Old May 10, 2022 | 07:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: What parts do I exactly need to rebuild my H22a4 with rod knock?
At a bare minimum, you will need to replace ALL damaged/worn parts plus a head gasket.
Old May 11, 2022 | 07:59 AM
ross2004's Avatar
If you got lucky, it's rod bearings + gaskets. If the knock came from starving it of oil, which is most likely, you'll probably need to add main bearings in too. If it damaged the crank, then a machine shop will have to repair it and now you're talking maybe $200 or so to turn and polish the crank (been a while since I've priced anything like that). You can get into some money quickly when a machine shop is involved.
nece228
Sep 1, 2012 01:16 AM
Tamotoji
May 14, 2011 02:29 PM
supercharged d
Jul 23, 2009 12:52 PM
typer_696
Jun 16, 2008 06:28 AM
limpy
May 30, 2004 10:33 AM
