need help with pilot bearing and clutch setup for my b16a build
Old May 8, 2022 | 11:42 AM
jaycorolla's Avatar
Default need help with pilot bearing and clutch setup for my b16a build
the situation that i am having is that i recently decided to rebuild my b16a motor, it had a flywheel attached to it and i had gotten it resurfaced. I forgotten that it was the flywheel for the cable trans. my questions are -
1. can i use the flywheel for my build which will be using a hydro transmission
2. if i can use the flywheel, which pilot bearing do i need?
3. which clutch and pressure plate should be used?
this is b16a motor and em1 transmission will be going into my EK. i would like to use the flywheel instead of getting new one since i already had it resurfaced. I also do understand that there are small spline and larger splined input shafts and thats why im asking about which pilot bearing and pressure plate should i use. i do know i have to use a clutch disc that matches that hydro transmission.
Please help me to finish this build, this is the very last thing that i need to do before putting in the motor and trans.
Old May 8, 2022 | 07:38 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: need help with pilot bearing and clutch setup for my b16a build
Clutch no but fly wheel will work.
question about clutch and flywheel between cable and hydro tranny - Honda-Tech - Honda Forum Discussion
raidacaipo
May 9, 2009 07:21 PM
meagainsttheworld
Sep 5, 2006 04:43 PM
matthevelli
Apr 7, 2005 12:01 PM
ridestrt
Feb 20, 2003 05:07 AM
handiman15
Feb 4, 2002 08:30 PM
