P1259 still on 2001 accord help please
Old May 7, 2022 | 07:34 AM
driver333's Avatar
Default P1259 still on 2001 accord help please
So I had the p1259 engine code a couple weeks ago and figured a new solenoid would fix everything, but it turned out to do pretty much nothing. The error code stops my car from accelerating normally, it takes a while to reach second gear, and driving over 65 makes driving car feel as if it’s gonna break down or overheat. It used to stutter and slip gears but that calmed down now unfortunately the code still shows and the little problems still occur. It isn’t the insufficient amount of oil as I make sure it has some every time I drive, and I can’t really figure what else it might be. Anyone have any ideas? Thank you
Old May 19, 2022 | 06:35 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: P1259 still on 2001 accord help please
It could also be the oil pressure switch for the solenoid is bad.
I would suggest verifying the wiring to both solenoid and switch are not damaged/correded/disconnected.
If the PCM is not getting a signal then it will set the code, verify wiring is in good order.
all77otorhead
Mar 5, 2024 02:45 PM
Matt Doan
Jul 22, 2016 08:54 PM
laloquera916
Jan 30, 2011 09:34 PM
Jonny-X
Sep 12, 2007 10:53 AM
fireblade2007
Jun 1, 2007 08:55 PM
