Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Can I use regular temp Hondabond for an oil pump?
Old May 5, 2022 | 10:44 AM
qsmith's Avatar
Default Can I use regular temp Hondabond for an oil pump?
Replacing the o-ring on my oil pump while doing a timing belt/water pump and oil pan gasket job. Removed the oil pump and it appears I will need to add some RTV on the mating surface when I go to reinstall it. Can I use regular Honda bond here (300 degrees max) or should I go buy some high temp permatex (500 degrees max) or wait two days to finish the job because of waiting for the high temp hondabond to arrive in the mail (600 degrees max)
thanks in advance
Old May 5, 2022 | 03:57 PM
qsmith's Avatar
Default Re: Can I use regular temp Hondabond for an oil pump?
This thread may be closed. This issue has been solved.
Corksil
Jan 25, 2011 10:36 AM
pjr710
Feb 24, 2009 07:05 PM
idriveadelsol7
25
Dec 9, 2005 08:47 PM
Galland
13
Jun 20, 2004 01:23 PM
