2013 CRV LX PART OF MULTI INFORMATION DISPLAY INOPERABLE
Some time ago, my wife informed me that she could no longer access the clock or the mileage indicator on the Multi-Information-Display.
I heard that it could be one of the following:
1. Blown fuse.
2. Disconnecting the battery could reset it when battery reconnected.
- The best I can tell, there is not a blown fuse (Easier to pull and see in engine compartment, not so much in passenger compartment).
- Tried disconnecting battery (Did it for a full 1 hour) and reconnecting. This did not work and caused the radio to be inoperable (The radio was able to be recovered with help from Tech8).
Is there anything else that I can try? Does anyone know what number (and where) the correct fuse is as I did drop one when I looked previously and don't want to do that too often.
Re: 2013 CRV LX PART OF MULTI INFORMATION DISPLAY INOPERABLE
Hi tech8-Thanks for the response:
I have tried the standard methods as shown in the manual.
- Using the display buttons does nothing, the screen stays blank. (None of Clock, trip computer or mileage displays appear).
- Same with menu button.
The fuse to check would be under-hood Fuse A29 (10A). But, that usually is if the multi-information display wasn't working. Sounds like it is partially working.
