Cooling issue
Old Apr 30, 2022 | 02:43 PM
sw20logan's Avatar
Default Cooling issue
Can’t seem the find the answer anywhere else, what should my cylinder head temperature sensor be at because everytime I drive my k swap the gauge will be reading normal but kpro is telling me that my cylinder head temp sensor will sometimes get to about 216 degrees, is that normal or should my cht be at 190?
Old Apr 30, 2022 | 07:22 PM
Ryanthegreat1's Avatar
Default Re: Cooling issue
186 is the target temp at the coolant temp sensor in the head. Matches the thermostat temp.
The gauge cluster temperature gauge is pretty dead and shows normal from ~150 to ~220.
One of my swaps would get hot going down the highway with a worn out half radiator in a 300k mile Insight. Went to a full width Integra radiator with custom end tanks and now it almost runs too cool.
Old Apr 30, 2022 | 09:22 PM
sw20logan's Avatar
Really? Ok I might have to invest in a bigger radiator but I didn’t think I needed one because it’s in a mr2 so it already has a full size
Old May 1, 2022 | 06:11 AM
Is it a healthy radiator or is it the stock 30 year old original?
Could also be a flow issue with all the extra coolant lines from back to front.
Old May 26, 2022 | 02:31 PM
Mr2kswap91's Avatar
Ever figure out your issue? Think I’m having the same issue. K24a in an sw20. After about 30 minutes of driving hondata is reading 218.
Old May 26, 2022 | 05:51 PM
sw20logan's Avatar
haven’t but I think I sorted it to my coolant leaks
ashtons300zx
Feb 24, 2012 03:29 AM
burntheblobs
May 26, 2007 04:44 PM
teamvirus
11
Sep 1, 2006 03:05 PM
eric416
May 21, 2006 09:08 PM
CiViC SiR
Jan 3, 2003 12:56 PM
