Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Starting problem please help
Old Apr 29, 2022 | 10:58 AM
DizzyDustin's Avatar
Default Starting problem please help
Ok so it's a brand new ruckus 2021 5000 miles or so couple oil changes and last week or 2 it hasn't been starting easy would have to hold the gas open to get it to fire and start and if throttle was let go to idle would automatically die I pulled it apart the fuel pump wasn't pumping like I thought it should replace it filters fuel and air and new plug but the plug Amazon sent was wrong went to start it and it won't start it fires and starter is spinning tire and trying to but it doesn't fire and start up I pulled the plug and checked compression it has compression so I poured a little fuel on end of plug tightened it up and tried to start it quickly and it started and ran full speed but when idle it just dies went to start again and won't start on its own any ideas on what could be causing this problem?? Thanks for the help
Old Jun 7, 2022 | 12:57 PM
jrotella's Avatar
Default Re: Starting problem please help
If you give it a little throttle on startup and hold it for a while to get the engine warm, will it stay running? Sounds like it could need a valve adjustment.
There is a great video outlining the diagnosis and adjustment process here:
ScooterPuppy
Jun 8, 2019 08:25 PM
Apple395
Aug 2, 2013 03:11 AM
Dynasty21
Oct 18, 2012 11:41 PM
ITR9788
Aug 24, 2004 07:45 PM
crxxrc
Feb 8, 2004 01:39 PM
