Brakes
Old Apr 28, 2022 | 10:31 PM
Jerry77's Avatar
Default Brakes
I just replaced my master cylinder and rear wheel cylinders bled the brakes and there is no leak that I can see not sure what to check next and my brake pedal still goes to the floor. My car is a 1990 civic sedan
Old Apr 29, 2022 | 06:46 AM
kraquepype's Avatar
10 Year Member
Default Re: Brakes
Did you bench bleed the master cylinder?
Old Apr 29, 2022 | 10:26 AM
Jerry77's Avatar
Default Re: Brakes
Yes I did
Old Apr 29, 2022 | 10:44 AM
Maxcapacity's Avatar
Default Re: Brakes
Did you measure and compare the piston depth inside the bore of then new master cylinder and compare it to the original and adjust the push rod on the pedal assembly leaving .02 gap between its contact point?
That or you could still have air in the lines. If you get the speed bleeders and use the hose connected to the nipple going into a jar, it makes bleeding a breeze.
Old Apr 29, 2022 | 10:47 AM
Jerry77's Avatar
Default Re: Brakes
No I didn't do that
Old Apr 29, 2022 | 10:50 AM
Default Re: Brakes
I would re-bleed and if it's the same, adjust the rod until your pedal feels normal.
Old Apr 29, 2022 | 10:55 AM
Default Re: Brakes
Also check your brake shoe contact. Pull on the ebrake and if it comes up all the way you just need to remove the rubber grommet on the back of the guard of the drum at the top and inside is the adjuster you flick up and click while rotating the drum until the brakes just start making contact with the ebrake off
Make sure to bleed each line in the correct order aswell..
Old Apr 29, 2022 | 12:58 PM
Jerry77's Avatar
Default Re: Brakes
Ok thanks
Stanceman
Dec 28, 2017 05:41 AM
94 IntegraLS
21
Jun 11, 2012 08:41 PM
imbest123
Nov 19, 2011 08:49 PM
wolve
Suspension & Brakes
Mar 1, 2011 11:27 PM
Arvid
13
Aug 4, 2004 03:34 PM
