Which gauge would you put where?
Old Apr 28, 2022 | 03:10 PM
Stopsign32v's Avatar
Loved
Default Which gauge would you put where?
Well I can't bring myself to install an A-Pillar gauge pod. It is just too basic and lazy. So I decided to go the Ortiz route and got a vent pod and will be replacing my clock I guess for a dual pod there (will miss my clock though )
So with that said, which of these gauges would you guys put where?
Old Apr 28, 2022 | 03:49 PM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Which gauge would you put where?
Id go with an afr gauge over boost.
Old Apr 28, 2022 | 03:52 PM
Loved
??? I'm going to use them all. Just wanting opinions on where you would place each.
Old Apr 28, 2022 | 03:54 PM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Ohhh i didnt notice the afr gauge.
Id get the cluster bezel mount. Easier to see it all.
Id go with afr priority
oil pressure second
boost last.
Old Apr 28, 2022 | 03:56 PM
Loved
oil pressure second
boost last.
I don't want to half cover up my fuel and coolant (or any other gauge). Other than that I do really like the cluster gauge pod.
Old Apr 28, 2022 | 04:39 PM
ohisofly's Avatar
If you want an idea for them in the cluster here's what I did - the middle of them lines up perfectly with the center of the tach and speedometer so I can still see everything. You can buy 3d printed column mounts that sort of accomplish the same thing but the ones I saw mount the gauges fully on top of the column cover, which is too high for an EF at least. Get creative with notching and you can get a much more ideal fit in my opinion
Old Apr 29, 2022 | 06:50 AM
DaX's Avatar
DaX
Loved
Community Favorite
With the bezel you have and the one you plan to buy, I'd do AFR in the vent and oil / boost in the clock. I understand the struggle - I went through this on my build, but just ended up doing the A-pillar triple gauge pod, and added a 4th to a blank spot on my dash (mine is an EG though).
maxwellmercer
Oct 20, 2010 01:31 PM
JDM_EK4_Coupe
Jun 19, 2007 03:49 PM
Capt. Jimbo McSubipants
Jul 7, 2005 05:25 PM
