90 ef d15 dpfi rough idle then clears out and throws code 5
Old Apr 17, 2022 | 04:34 PM
Codyro817's Avatar
Default 90 ef d15 dpfi rough idle then clears out and throws code 5
Inherited a 90 ef hatch with d15b dpfi. Replaced alot on it just to get it in the current state. Timing belt, water pump, headgasket, throttle body gasket, thermostat, coolant fan switch, gas tank, fuel pump, main relay(have 3 on hand), and map sensor(also 2 extra). Car starts fine just has a little rough idle when cold, but I've been chasing code 5. Car has a roughish idle when i first start it, and after the CEL for code 5 appears, idle smoothes out, but i can tell it's running a little rich. I've replced all the vacuum hoses, just don't know where to go from there as far as if it's an actual mevhanical issue. I have drove it around the block a couple times abd down the street to fill it with gas, just don't know what else I'm missing.
Old Apr 18, 2022 | 05:23 PM
Codyro817's Avatar
Default Re: 90 ef d15 dpfi rough idle then clears out and throws code 5
Did recheck timing today and that's not the issue, will check ignition timing tomorrow. Book is kinda vague on mechanical timing but ignition timing is in there
Old Apr 19, 2022 | 04:53 AM
scelestus's Avatar
Caveat: I haven't messed with a dual point in a long time. Since you did the tank/pump, what's the state of the fuel return system? I would cap off the purge system at the intake to see if anything changes.
Pretty sure it runs smoother with the code because the ECU is dumping fuel - that's what seems to happen under an O2 code, so I'll bet this is similar.
Old Apr 19, 2022 | 05:14 AM
Codyro817's Avatar
I'll try that today, just would figure I'd have a different code then code 5 for map.
Old Apr 19, 2022 | 06:31 AM
scelestus's Avatar
Honda OBD0 is oblivious and unhelpful. You only get 20ish codes after all. Always try to think of those as pointing generally to systems, not specific components.
SlipGear
Jun 26, 2008 05:37 PM
EFb18b
Jun 7, 2006 01:17 PM
UNKNOWN_MEMBER
Jun 27, 2005 08:15 AM
Glocked1
12
Jan 22, 2004 08:13 PM
