92 inegra need help
I have a 92 integra with B20 engine I have engine code that keeps popping up and replace both sensors on the throttle body code 3 code 7.
I replaced the grounds thinking that would help and it's not working.
Any ideas if so let me know. Thanks
Make sure they are not plugged in the wrong spot, i do believe the MAP and TPS share the same plug housing. Ive seen this happen on B series swaps.
But deff. make sure the TPS is calibrated you need a volt meter to do this!
