Ignition timing
I took my dizzy off, but before that I put marks on the dizzy and the engine to mark how it was before.
Then i installed the same dizzy back so the marks line up.
The ignition timing should still be right or am I wrong? Do I need to adjust the timing?
If you marked the distributor and cylinder head mounting point, align those marks when re-installing the distributor and the timing should be the same.
