dizzy issue
Old 11-25-2012, 11:39 AM
dirty5outhazn's Avatar
Default dizzy issue
My ignition timing is retard and I have more adjustment to advance it. Its causing it to run really rich. Alot of hesitation at low rpm. Is it my dizzy? My mechanical timing is dead on.
Old 11-25-2012, 11:41 AM
The Grumpiest
grumblemarc's Avatar
Default Re: dizzy issue
How about ignition timing?
Old 11-25-2012, 11:44 AM
Its still retard and my dizzy is advanced as far as it can go.
Old 11-25-2012, 11:48 AM
The Grumpiest
Erg. You said that.
What car? What mods? You're leaving out something.
Old 11-25-2012, 12:08 PM
Ridin Dirty in Cali
dirty19's Avatar
I cant read minds, I gave that up when I was 12.
More information please.
Old 11-25-2012, 12:16 PM
Sorry. Its a ls vtec with b16 pistons. Stock b16 head.Chipped p28 with stock gsr map..
Old 11-25-2012, 01:38 PM
Anybody?
Old 11-25-2012, 01:40 PM
The Grumpiest
Not really. Not enough info on your build. Is this a new issue? Just started happening?
Not.
Enough.
Info.
Old 11-25-2012, 03:12 PM
Sorry man. Well I bought this dizzy new off eBay a couple years back for my b16. Seemed to work fine other than the position of the dizzy to get the ignition timing right seemed way advanced but after checking with a light it was dead on so I just drove it as is was and I never had any problems. A couple months back I decided to do a ls vtec. So I rebuilt a b18a1 block with b16 pistons and just reused my complete b16 head. I've checked the mechanical timing a hundred times and its dead on. But when I set up my ignition timing I always start in the middle and rotate towards the firewall till I've reached the correct posision via timing light. For some reason even with the dizzy rotated completely back its still off. I've tried multiple different base maps. I'm lost. Rotor button, cap, wires, and plugs are all good.
Old 11-25-2012, 03:42 PM
Master Detailer
98civdx's Avatar
Are you jumping the service connector?
Old 11-25-2012, 04:38 PM
Yep. Every time.
Old 11-25-2012, 05:11 PM
91legend's Avatar
This is why you should just get a brand spanking new distributor with a warranty on it. I bought a "oem replacement" turbo for my Audi I had. It sounded like crap and boosted even worse than it sounded.
Don't go to autozone though... I'm on my 4th autozone distributor in less than a month..
Old 11-25-2012, 09:41 PM
Damn what the hell. Did you have any problems similar to mine?
Old 11-26-2012, 03:41 PM
Up.
Old 11-27-2012, 05:49 AM
Project Dad's Avatar
I am having the same issue on a d16y8. timing is retarded. taking all bolts out and advancing far enough to were the bolts can be put on the outside of dizzy holes with washers holding the dizzy in place, it runs perfect. I am left with knock sensor (new one coming) or ecu.
not trying to thread jack, just letting you know that I am having same problem.
Old 11-27-2012, 06:10 AM
Have you tried another dizzy?
Old 11-28-2012, 12:08 PM
yes from a running car. knock sensor made no difference
TSI_Xtreme
03-05-2013 04:32 PM
category5 SI
03-14-2010 04:45 PM
blackcrx16
06-15-2007 09:10 PM
peel17
01-23-2006 02:30 PM
Quick Reply: dizzy issue
