Coolant Leak
Old Apr 3, 2022 | 09:35 PM
Alex_Robbos543's Avatar
Icon3 Coolant Leak
Hi again, Ive been servicing my 98' Lude and found a leak on the back passenger side of my block, its a steady flow of about 5 drops every 30 secs ( Coolant btw ) .
However i haven't been able to find any loose hosing for this leak, there is no threading in the hole either, Would this be heater core hosing or water pump?
I have though found a little straight no thread screw with a spring , similar to one you'd find in your thermostat , it fits in the hole but it wont stay.
any words of wisdom is appreciated;
- Robbo
Old Apr 4, 2022 | 10:39 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Coolant Leak
If it is leaking coolant out of a hole, it probably is the water pump weep hole.
Water pump will probably need to be replaced.
Old Apr 10, 2022 | 02:07 AM
This is where it’s leaking from, is that there Weep hole ( edit : just the 2nd photo btw )
Old Apr 10, 2022 | 02:08 AM
Old Apr 11, 2022 | 09:10 AM
ross2004's Avatar
Yep, that's your water pump.
Old Apr 12, 2022 | 12:20 AM
cp6xh's Avatar
Would it be hard to change the water pump for someone who has never changed the water pump before?
Old Apr 12, 2022 | 05:30 AM
ross2004's Avatar
It's not the easiest thing in the world. When you do a water pump you'll do the timing belt as well, so you can look up procedures for that to get an idea of what's involved.
Old Apr 12, 2022 | 06:15 AM
cp6xh's Avatar
Thanks Ross
Old Apr 16, 2022 | 05:05 PM
SteppinRazor's Avatar
I had a leak on the passenger side back of engine. It was a cracked heater hose. Kind of a b*tch to get to the firewall end, but very doable. Took maybe an hour, with most of the time spent contorting my hands, and draining the coolant.
SethS0114
Apr 13, 2021 08:46 AM
Yao Saechao
Mar 26, 2018 01:25 AM
wildoutwhitegsr
Jan 6, 2006 12:34 PM
Allstar
Feb 26, 2003 05:55 PM
