Crx Starts but as soon as I hit gas it dies and has cel code 3
Old Mar 30, 2022 | 10:03 AM
jahaziel_col's Avatar
Default Crx Starts but as soon as I hit gas it dies and has cel code 3
Crx Starts but as soon as I hit gas it dies and has cel code 3, before this OEM sensor was melted, changed it for a skunk 2 4 bar map sensor. Ecu is chipped P28.
Old Mar 31, 2022 | 11:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Crx Starts but as soon as I hit gas it dies and has cel code 3
Did you change the tune to accept a 4-bar MAP sensor? You can't just go from a 1-bar MAP sensor to a 4-bar MAP sensor without changing the MAP sensor scaling in the tune.
Old Apr 1, 2022 | 05:44 PM
Gave the ecu to tuner he tuned for the map sensor but now it only revs to 3-3,500 rpms, with solid cel and still map sensor cel.
Old Apr 2, 2022 | 02:45 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Your MAP sensor melted too? Some of the glue(?) on the bottom of mine melted off leaving a drippy mess, and I have drive-ability issues too. No CEL though. So I was looking for similar info. I read a little bit of service info and found this:
Disconnect MAP sensor hose (#21) at vacuum source & apply 20"hg. Vacuum should hold stable. If vacuum bleeds off, check hose carefully. Deteriorated vacuum hoses are common. If hose is OK, check MAP sensor separately to see if it holds vacuum. Repair all vacuum leaks before checking MAP signal.
and
DC Voltage Test
Yellow=MAP signal
Black=known good ground
KOEO, voltage should be about 2.9V at sea level. KOER, warm idle with 20" hg of Engine vacuum, voltage should be below 1.0V. As vacuum decreases MAP voltage will increase. Voltage should change smoothly with no drop outs or glitches during test.
I wonder if the Skunk MAP works differently as far as voltages go though. Probably depends how the tuner did it... no idea how tuning these things work.
Old Apr 3, 2022 | 05:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
The way these sensors work is they convert pressure to a 0-5V signal. The difference is that the stock one only has a range of 1790 mbar (25.96 psi) and the typical 4-bar sensor has a range of 4228 mbar (61.32 psi). Remember that these are Manifold Absolute Pressure sensors, so the reading is the manifold pressure plus atmospheric pressure. Subtracting out atmospheric pressure (standard is 14.70 psi / 1013 mbar, but this can vary depending on elevation and current weather conditions) you get a range of 11.26 psi for the stock sensor and 46.62 psi for the 4-bar sensor.
What does all this mean? The ECU only cares about voltage - it knows nothing about pressure. Both stock MAP sensor and 4-bar MAP sensor will put out the same voltage, but at different pressures.
Let's look at an example, and we'll keep pressures in mbar for consistency. My Civic idles around 701 mbar below atmospheric pressure (1013 mbar), so 312 mbar absolute pressure. On a stock sensor, this equates to 0.97V. On a 4-bar sensor this equates to 0.32V. So if your car is tuned for a stock sensor but you're running a 4-bar sensor, the sensor is outputting 0.33V, which the ECU is interpreting as 75 mbar absolute pressure, or 938 mbar below atmospheric pressure. It thinks it's in a deeper vacuum than it is, so it's going to under-fuel and cause it to run poorly.
Old Apr 8, 2022 | 02:48 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Thanks for the info!
Do you think the melted glue on the bottom of my MAP sensor would indicate a problem internally? It held vacuum but I never tested the voltage coming in/out.
No codes for it, but my car seems to be running hella rich and basically undrivable.
Old Apr 10, 2022 | 03:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
I haven't experienced melted glue coming out of a MAP, but i would either try testing or just replacing it.
specificcivic
10
Aug 19, 2007 10:54 AM
jdmslim
Mar 28, 2005 03:22 PM
jArceo
Oct 14, 2003 05:02 PM
Nerv2g
Sep 22, 2003 05:07 AM
