Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
delete/bypass 05 honda civic ex ecu variable timing solenoid - 1.7l engine
Old Mar 28, 2022 | 04:14 AM
Jimdanger's Avatar
Default delete/bypass 05 honda civic ex ecu variable timing solenoid - 1.7l engine P2646 code
I want to delete/bypass the ecu VTEC on my 05 honda civic ex 1.7l D17A2 variable timing solenoid because, someone swapped the motor with a D17A1 non-VTEC motor which triggers the P2646 code. Is this possible to reprogram the computer. Code P2646 tripped (ecu searching for functioning oil pressure switch).
I've read to swap ecu with a LX but I've read it doesn't work due to EX options that quit working.
I've been told to swap heads to another EX D17A2 head.
I've read to ground the oil pressure switch.
I've read to jump the oil pressure switch to the solenoid.
Which is the best, cheapest, or easiest option?
Natem254
Mar 28, 2022 09:38 AM
Pogusone
Aug 26, 2021 03:53 AM
Tim Hitzeman
Dec 8, 2019 11:39 AM
Vtec04
Oct 4, 2016 04:49 PM
rsxs77
10
Feb 1, 2014 04:19 PM
