Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Random rough idle issues
Old Mar 26, 2022 | 08:19 AM
kevhed's Avatar
Icon4 Random rough idle issues
Hi All,
First time posting a thread. My 2008 civic will occasionally experience rough idle issues. What typically happens is the car starts fine, will run fine for about 5 or 10 minutes, and then say i come to a stop sign or light...it will then start idling rough to the point of dying So I put it in neutral and give it some gas to keep it alive, and then once I take off, it seems fine. I don't experience any other running issues after that rough idle and it seems like once i get that one rough idle experience out of the way, the car is fine. So not sure if it's something temperature related.. sAnd the idle issue does not happen all the time...it's random and intermittent. Anyway, I've replaced the EGR valve, new injectors, new ignition coils, new fuel pump and finally a new maf sensor. So I think I have all of the major gas, air and spark components replaced. I just change the maf last night and this morning, I took it for a drive, and again about 5 or 10 min after driving, i stopped at a stop sign, and the idle bogged down and almost died. There never a CEL that goes on. The car runs great other than this one issue. I'm at a loss and just curious if anyone else out there may have experienced the same issue
Thanks
Old Apr 19, 2022 | 03:43 PM
Civiccritic's Avatar
Default Re: Random rough idle issues
Originally Posted by kevhed
Hi All,
Thanks
yes, I have a 2009 civic. Stock and have a very similar problem. Idle low only after warm up, after countless hours of searching, and replacing parts (no codes) was advised from another website that a honda technician said they have had sucsess in doind a ckp learn procedure and seems to have fiked the problem. Good luck!
Campo7
Honda CR-V & Element
Jan 6, 2020 03:19 AM
ashe
Aug 6, 2003 11:18 AM
Accelerated
Mar 25, 2002 06:45 PM
