Accord swap distributor help
Old Mar 11, 2022 | 10:24 AM
Jay castro's Avatar
Default Accord swap distributor help
I have 2002 accord running an f20b engine never came with distributor I put an obd1 internal coil distributor on it but I知 hearing I should run an obd2 distributor but if I知 doing an obd2 down step to obd1 would this cause any problems?
Old Mar 13, 2022 | 05:36 AM
GhostAccord's Avatar
Default Re: Accord swap distributor help
You would need to wire the TDC, CKP and CYP sensors accordingly. 2002 Accord would have had 2 of the 3 sensors located down behind the crank pulley / mounted to the oil pump housing. While the OBD1 engine would have all 3 sensors located in the distributor.
Also have to watch that the distributor that you are using isn't out by 180* once it is mounted on the engine. I know this was an issue for some F22 engines, I'm not 100% on the differences between the F23a and F20B obd1 and obd2 distributors though.
Angeljavier3577
Apr 30, 2018 01:41 PM
killakalipoph
Jan 18, 2012 03:47 PM
minighi
Aug 9, 2011 07:47 PM
ej8_fredi
Mar 28, 2009 11:10 PM
Astr8upfella
Jan 20, 2002 01:30 PM
