Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Honda Civic Clutch problems (PLEASE HELP!)
Old Mar 5, 2022 | 07:04 AM
UriahF's Avatar
Default 2007 Honda Civic Clutch problems (PLEASE HELP!)
I have a 2007 Honda Civic 5 speed manual. I pulled over in a parking lot yesterday to change my shirt and my car was running just fine. After parking, I tried to press in the clutch (so that I could reverse out) and heard a single loud snap. I can no longer shift it into gear while it is turned on, and if I shift it into gear while off it spits and sputters/will not start when I try turning the key. The pedal still has resistance and raises itself back to the initial position. I did not see any liquid leaking anywhere, no screws or bolts missing/laying around, and no broken/disconnected springs and wires. Any advice is greatly appreciated.
Old Apr 5, 2022 | 07:09 PM
spirit_wolf's Avatar
Default Re: 2007 Honda Civic Clutch problems (PLEASE HELP!)
Is the shift cable still functioning? If so pull off the inspection plate under the car on the transmission and have a peek in there at the flywheel and clutch to see if the clutch is shattered may have to rotate the flywheel manually in neutral with car off.
JN77
Honda City
Feb 4, 2023 07:14 AM
RevYouUp
Aug 9, 2018 08:34 PM
Darth Naga
Jun 7, 2012 01:20 PM
alicia328
Honda Civic (2001 - 2005)
15
Apr 13, 2009 07:31 AM
