D16Y8 swap into 1991 CRX (AUTOMATIC)
Old Mar 5, 2022 | 05:57 AM
Slumbs's Avatar
Default D16Y8 swap into 1991 CRX (AUTOMATIC)
So i recently bought a 1991 Automatic Honda CRX. The engine went and I decided to purchase a D16Y8 engine from a 1995 Manual Civic. The guy doing the swap for me is keeping the CRX Automatic. But he says that all of the fuel injectors won’t work because of the wire harness. What I would like to know is what kind of harness do I need to make everything work properly.
(I did get a new ECU for the swap, bought a new intake/exhaust manifold) If their is any more information I could give to help answer this question please ask.
Old Mar 5, 2022 | 11:43 AM
Chrisfrom1986's Avatar
Default Re: D16Y8 swap into 1991 CRX (AUTOMATIC)
You can only use the original engine and ecu with an automatic. There is nothing you can buy that will make whatever mix up of parts you're trying to throw together work.
Old Mar 7, 2022 | 11:32 AM
DaX's Avatar
DaX
Loved
Community Favorite
Well...at least not make it work 100% correct.
OP could drop just the D16Y8 long block into the CRX and reuse everything else that was original to the CRX's (intake manifold/injectors/sensors, distributor, wiring harness, and ECU) and have something that runs, though VTEC won't work.
Old Mar 7, 2022 | 04:10 PM
Slumbs's Avatar
If I use the CRX’s stock ECU + Wiring Harness would that allow all the fuel injectors to work on the D16y8?
Old Mar 8, 2022 | 04:19 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yes. Which trim CRX are you working with, and what is/was the original engine?
Adir Cohen
Mar 22, 2020 09:31 AM
Cody Griffin
Mar 10, 2018 12:48 PM
devoncll1
Mar 10, 2017 11:21 AM
pumpkyn
15
May 8, 2006 10:50 PM
