Error Codes 83-11, U0416:68 and P0B3B:03
My Honda Vezel 2015 is showing the following error codes.
83-11
U0416:68
P0B3B:03
Local mechanic says to change hybrid battery pack as internal circut malfunction error relates to battery.
I Have changed stearing box and after washing the car, these errors started appearing.
Power System icon
Stearing
VSA.
Kindly guide me what needs to be changed to fix the issue.
83-11
U0416:68
P0B3B:03
Power System icon
Stearing
VSA.
Hey Brother, Any chance you were able to solve your P0B3B:03 error without replacing battery? I have a honda CRZ and also having same error although my battery cells are totally fine and balanced
I did the following 2 things.
1. I change auxiliary battery as its health was not good. And the issue resolved for a week.
But the error reappeared.
2,And then I found that the AC Filter is extremally dirty due to which AC was draining the Hybrid Battery.
So far the issue has not appeared again. I will update you if it appears again.
hallo bro
my problem pob3b. I had a bad battery under the hood.
the car was giving an error vsa abs low battery and ima.
I changed the new battery and the errors vsa and abs are gone.
only left ima and battery icon.
what AC filter are you talking about?
THANX
THANX
YamahaSCER6
Dec 19, 2020 07:37 AM
Mr. Mark
Mar 6, 2018 05:52 PM
