Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Electrical issue
Old Feb 25, 2022 | 08:32 PM
Zach hunter's Avatar
Default Electrical issue
My gauge cluster back lighting and back lighting behind all of the radio buttons and the window and lock buttons all turn off and on constantly.
Old Feb 26, 2022 | 05:19 PM
Ryanthegreat1's Avatar
Default Re: Electrical issue
Failed lighting dimmer in the gauge cluster.
You can try turning the brightness down to see if the flashing stops.
Probably going to need a new cluster or find someone that will do component replacement on your cluster.
Old Feb 26, 2022 | 06:02 PM
I turned the brightness down and all the lights still flash so did the Lighting dimmer fail
Old Feb 26, 2022 | 06:36 PM
Very likely. Turning down the brightness doesn't always stop the flashing.
Old Feb 26, 2022 | 06:39 PM
Oh. Also my fuel gauge jumps up when it flashes then rests back down. And I’m not getting any rpm signal or mph signal. And when everything flashes all the dummy lights pop back on and then turn off.
Old Feb 26, 2022 | 06:40 PM
Do you think it’s possible that the whole cluster is shot?
Old Feb 26, 2022 | 07:09 PM
Sounds like the cluster is losing power/rebooting for whatever reason.
Could be a bad cluster.
Old Feb 26, 2022 | 07:13 PM
Yeah, it’s the weirdest thing, I’ve checked all relays and fuses. And all the grounding points in the engine bay for the tranny and the engine and even the bevy battery cable.
Do you know if their is a way I can test my gauge cluster?
Old Feb 27, 2022 | 06:55 AM
You could remove it and power it up on the bench. Will need a pinout for the cluster so you know where to apply power and ground.
Old Feb 27, 2022 | 07:16 AM
Okay I’ll try it.
Old Feb 27, 2022 | 05:17 PM
Also in the morning on a cold start my engine makes a rattling noise for like 2 seconds then goes away. Happens only on a cold start. What could that be?
Old Feb 27, 2022 | 05:22 PM
Look up VTC rattle.
Old Feb 27, 2022 | 05:23 PM
Okay I’ll check that out.
Old Mar 9, 2022 | 12:37 PM
Do you know where I can get a Pinout of the gauge cluster?
f575gtc
Honda Civic (2001 - 2005)
Jan 16, 2015 01:48 PM
snowblind7x
Aug 9, 2006 11:23 AM
Racersky
Audio / Security / Video
Nov 16, 2005 11:45 AM
WH0R3nEF9
Mar 28, 2005 06:50 PM
