Need help converting distributor coils
First I want to say thanks in advance. I looked in the FAQs and looked at the external to internal coil but I couldn't make heads or tails of it for my situation.
I have a 1994 Honda Accord LX Wagon. For my own reasons I decided to swap my F22B2 cylinder head out for the Vtec F22B1. I went to the junkyard and found a perfect donor, a 1994 Honda Accord EX Sedan. Both Cars are OBD1 (no oil pump region crank sensor) and basically a factory upgrade path from LX to EX. I took the EX Distributor, ECU, and the F22B1 head with me. After refurbishing the head, seals, and lapping the valves I swapped it onto my F22B2 block. Originally I was going to stick with the LX external coil distributor. I overlooked the fact where the coil mounted was exactly where the vtec solenoid is now. I figured "oh well I'll just make another bracket and keep it anyway". After considering a few things including parts pricing and spares I have, I decided to swap to the EX distributor (the internal coil model). I still have the factory LX external coil wiring harness and need to know what wire to depin and where to repin or connect it to make it work for the EX internal coil. The coil wiring on my LX harness has 3 wires: Green, Yellow, & Black with Yellow Stripe. If I have to extend something it's no big deal I do have wire and connectors to use. Thank you again. Any info helps. I can provide additional information if needed.
97Accord5spd
Dec 28, 2021 04:22 AM
chrisnick
Sep 10, 2015 03:05 PM
twentyhurtz
Sep 29, 2013 06:02 PM
