Are adjustable coilovers as much of a PITA as I’ve led myself to believe?
The initial setup is kinda a pain in the ***, but not horrible.
Especially when you disconnect the sway bars.
Set ride height, then alignment, then drive to settle it. Double check it. 👉
THEN reconnect sway bars.
You may need adjustable end links to allow for no preload on the car from the sway bars.😁
👀👀LOOK, what a beautiful coilover‼
