Suspension & Brakes Theory, alignment, spring rates....
Integra bad brakes no abs
Old Feb 17, 2022 | 06:10 PM
dlx111's Avatar
Default Integra bad brakes no abs
97 integra with abs
mini cooper rotor + prelude/type r front caliper front brake upgrade
stock rears
stainless lines front and rear
metallic pads
abs light is on, fluid level is correct i both abs unit and brake mc. Replaced the abs pump o ring on the pressurized canister. Bled all brakes and bled abs pump.
brakes lock up when stomping on pedal and braking performance under normal pressure is 6/10 at best.
i want crisp quick brakes especially with the bigger fronts. Thinking of just eliminating abs unless theres other ideas?
c|rop3asy==[]
Jun 14, 2011 06:22 PM
EJ2-Fluffy
Oct 11, 2010 10:23 AM
lewdude
Nov 24, 2004 03:09 PM
JeremyL
Jan 30, 2003 03:26 PM
