16" to 15" wheels - downgrade to smaller calipers?
Has anyone downgraded to the smaller 02-04 calipers on an 05-06 CRV? I want more rubber without increasing too much height, not to mention the selection of AT tires seems so much better with 15", therefore, my solution would be to go to smaller wheels. So other than calipers & brackets, what else would be needed? Can the original knuckle, bearing, & hub be retained? ABS sensor? ... And same for the rears?
The rear calipers won’t make the difference; where the caliper mounts to as it relates to the knuckle is different. You’d need to swap the knuckles if you want to run smaller rear rotors.
