Am I wasting my time looking into turbo-ing my k24a8 accord?
I have been doing some searching and I haven't found any k24A8 turbo builds with much information so far. The one thread I found, there was a guy saying they won't handle any boost and it's a waste of time. Another guy in the same thread said it's the same motor as the a4 just with a different camshaft and with DBW. Can anyone tell me whether or not this is true?
First off, let me say I haven't built up a piston engine before, and I don't have experience with turbos. I do have experience with rotary engines, but I don't think that's really gonna help with this.
My goals for the Accord would be 225-300HP without a lot of turbo lag, so I'd probably want a smaller turbo that spools fast. Would that be possible with stock rods? stock pistons even? People with 24A4's have apparently built 400hp turbo motors on stock bottom end.
Is this a reasonable goal for a bone stock 150k+ miles k24A8? Would I need a rebuild? I'm not afraid of doing the work, just not looking to spend a million dollars on this. I could call up my friend who owns a junkyard if I would need TSX or Accord 24A4 rods or crank or some other pieces, he sees 24A4 accords all the time and an occasional TSX. Or I could just get some aftermarket parts too. Again, I'm new to building piston engines so thanks for being patient with me
Sounds like a weird build, but - https://www.k20a.org/threads/k24a8-f...-360tq.111911/
I'd probably just stick to something more traditional. If you're doing this because it's your only car and you want it to be faster, you're likely to give up a lot of reliability and drivability. Better off just selling it and getting something else.
When you say more traditional, what do you mean? NA build with TSX head? Something similar?
Yes, either a car or an engine that is much more commonly built. There will be more informationl resources available and more aftermarket support. Overall, it would likely be easier and cheaper.
Well, I think for now I won't be getting a new car. At least until the market calms down. I got this accord because it $1700 and it was the only thing that was non-rusty, manual, and running for under 15k. But I could easily get a TSX A2 motor, and since I'll need a tunable ECU no matter which direction I go it seems like it might be the move.
Nope. The K24A8 is the next version of the K24a4 i guess with a slightly better intake cam. You dont really see people opting for it because its a lil more rare (07-08) only, and they just go for the K24a4. It is DBW so its best to stay with what ever u got currently. You could turbo it with Ktuner and get and 240-285whp safely with it. I currently have a 2007 with a k24a8 and going to swap it out for a K24a2 and Z3 civic Si gear set with lsd. The stock accord gears suck lol.
I have a 2006 Honda Accord coupe K24a8 (5 speed manual) that I’m planning on getting turbo mode as well. Funny enough, I paid $1800 for this 187,000 mile car. A year later it has 198,500 miles, and it’s also getting a turbo. I had a shop (specialize in race builds) tell me it’ll be fine because I’m also not aiming on 600hp, just wanna spice up my driving a little as well. Aiming on 300hp just to make my highway drives a little more fun. I think you should be good. Did you get it done?
My plan at this point, if I don't sell the Accord for something else, is to get
-A spare engine (if I can get one, I'll go for a K24A2)
-A turbo manifold off Ebay, I have a turbo from a friend
-A Speeduino UA4C ECU, which will probably require me to switch to
-A cable throttle body
I'd ideally like to get something that can run on an engine stand, while also having a running car. Then I can drop it in with minimal downtime. But I admit, this is a little intimidating to a beginner like me, even with all the research time I have into this. It probably will be a while before I can get this put together.
NucAcc
Oct 30, 2014 08:42 AM
