02 Civic OBDII not reading, immobilizer key flashing, no start.
I have an 02’ Honda Civic that’s not starting, it cranks fine but no start, changed the battery, checked the fuses, checked fuel pump and looked fine. I decided that the immobilizer green flashing key was the most likely issue so I tried scanning it but my scanner had no communication to the original ECU so I got one from the scrapyard after I had a technician tell me the original ECU was no good but still have same issue. The OBDII port has power as when I plug it in with multiple scanners the scanners recognize that it’s connected but try to read but fail to. I need help figuring out how to get my scanners reading the car in order to bypass the immobilizer. I really don’t want to junk the car because it’s still in decent condition with low mileage someone please help I’d be greatly appreciated!
I've heard people have luck checking the #9 fuse in your engine compartment.
Other than that, grab a voltmeter.
Pins 4 and 5 are grounds
Pin 16 is power from that fuse IIRC
Dont mess with the others becuase they are for communication and could mess up a bunch of other stuff.
Merrill Balan
Feb 25, 2023 05:24 PM
spyz34
Mar 20, 2005 12:49 PM
