Starter problems on b swap ef hatch
Having problems with starter. It clicks when I turn key but won’t spin. Almost like it gets stuck. Got a new starter. No change, got a new battery no change, got new alternator, new ignition switch, and new starter relay. Still not working. When I click it multiple times it ends up turning over the car
Sounds like you have a bad ground.. I would check and clean the ground wires to chassis from the battery and also clean the terminal connections to the battery. Make sure you have a good ground going to the tranny and one to the chassis.. Also just double check the voltage from your new battery..
DriftStaRSi91
14
Jun 19, 2011 11:55 AM
