Other than bolt pattern, are they the same? Are the wires any different? I do know the plug is the same. First picture is from a 2006 Y8 EK and second picture is from a 90 civic EF.
I've searched the forums and there's mostly just posts about people having issues with their IACV.
Re: Is there any real difference in these two IACV?
Originally Posted by Caoboy
If it plugs in, then it’s the same 2 or 3 wire.
but do the bolt holes line up?
A little bit of information since I left it out. The car is a 1990 civic STD hatchback with a D15b1, I did a MPFI swap and used a manifold off a d16y8
I'm mostly just curious if the two I posted in pictures above function the same since I've been dealing with idle surge issues when the car warms up. There's a million posts about idle surge I already know. Just trying to make sure they're the same and cover all the variables since I didn't have this issue before the swap.
