Honda CR-V & Element 2WD & 4WD Element & CR-V
VTEC woes
Old Jan 29, 2022 | 03:36 PM
porscherules's Avatar
Default VTEC woes
Hi all, newbie here. My Honda is a 2006 CR-V SE and I'm having problems with my VTEC solenoid. I've read a large number of threads/articles on how to replace the VTEC solenoid and clean it's screen and still can't find a answer to my, seemingly, particular problem. Ok, so the car is now in limp mode and here's what I did to get it there. The solenoid gasket was leaking - the car ran fine, so I ordered a new solenoid (not OEM), Put the new solenoid in and the car immediately went into limp mode. Ok I think, so the original worked and I've read that after market vtec solenoids often don't cut it, so I put it the original back in with a new gasket (the original was working fine originally). Fired the car up and it immediately went back into limp mode. At this point I'm thinking that maybe I broke a wire. So I go looking for information about the VTEC wiring and this stopped me cold. Every article I read had the solenoid with just one wire - mine has two - a green/yellow and black (see pic). I assume the black is ground (but why the "extra" ground?). The oil pressure switch has two wires, a green and yellow (see 2nd pic). I'd like to test for continuity and/or voltage using these vtec connector pins. Can anyone out there tell me if I can easily check for voltage on these wires and, if so, the readings I might expect to get. All information is appreciated.
Thank you in advance
Old Jan 29, 2022 | 04:04 PM
Ryanthegreat1's Avatar
Default Re: VTEC woes
What is the specific code you are getting?
Old Jan 29, 2022 | 06:39 PM
ajchien's Avatar
Yeah, knowing the code will allow you to limit your testing.
the solenoid has a power wire and a ground wire, power is applied when the ecu wants vtec.
the pressure switch wiring has an ecu wire and a ground, it is a 12v pull-up circuit with a normally closed switch. 12v on the ecu wire when the circuit is open, 0V on the ecu wire when the circuit is closed and grounded.
Old Jan 31, 2022 | 11:16 AM
Unfortunately, it's in limp mode and I can't drive it anywhere. And, the ODB II reader I purchased, simply gave a reading of "error." Not much help.
Old Jan 31, 2022 | 11:18 PM
ajchien's Avatar
Seems like a good reason to upgrade your scan tool.
Anythingbtcivic
Oct 21, 2017 11:53 PM
crxbrad
Aug 20, 2011 06:51 AM
joelmatt89
12
Feb 20, 2009 07:08 PM
xXSilentScreamXx
16
Aug 24, 2007 10:53 AM
