Honda Accord 2016- 2017 This is the place to discuss all things Honda Accord related for the 2016 -2017
2017 Accord EX-L Coupe Passenger Door Latch Handle not opening from outside
Old Jan 25, 2022 | 05:19 AM
JLe99's Avatar
Default 2017 Accord EX-L Coupe Passenger Door Latch Handle not opening from outside
Body shop took my door and put it back on and the first time the passenger door didn't lock from either inside or outside so they fixed that and now it locks from inside just fine and outside but the door will not open when pulling on the handle from the outside. What could be the problem?
notes: latch on the door isn't moving when pulling on the handle either
Old Jan 25, 2022 | 06:04 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2017 Accord EX-L Coupe Passenger Door Latch Handle not opening from outside
It should be the body shop fixing this if you got the car back like that.
Possible cause may be the door latch rod was not attached back correctly to the base, or damaged base, or damaged outer handle, or latch.
The outer handle (9) attaches to the base (11), the rod (2) is attached to the base (11) and latch (1).
Scott Younker
May 28, 2019 07:33 PM
digihonda
Nov 4, 2013 07:25 PM
rubenmed
Nov 25, 2012 01:46 AM
JDMEK108
Jun 14, 2010 01:07 PM
hondaaccordingly
Mar 2, 2009 07:18 AM
