Misfire/low power after warm up below 2500 RPM on 1991 Honda CRX
Old Jan 23, 2022 | 02:14 PM
vstevenson96's Avatar
Default Misfire/low power after warm up below 2500 RPM on 1991 Honda CRX
Hi,
On my 1991 Honda CRX Si (fuel injected), after warm up, the car misfires and idles during acceleration below 2500 RPM (above it is normal). I have been troubleshooting this for a while and would like more input. Here are the parts that I have replaced for this issue:
1. Fuel pump
2. Spark plugs
3. Fuel filter
4. Air filter
5. MAP sensor
6. Vacuum hoses to the MAP sensor
7. ECU
I have also checked the resistance to each of the injectors and they are all 2.2 ohms (within the FSM spec of 1.5-2.5 ohms).
I plan on next replacing the fuel pressure regulator and cleaning the injectors.
I am wondering if I am missing anything obvious?
There are no check engine lights and the ECU is not throwing any codes.
Any help is much appreciated.
Thanks!
Old Feb 21, 2022 | 07:44 AM
aw614's Avatar
10 Year Member
Loved
Default Re: Misfire/low power after warm up below 2500 RPM on 1991 Honda CRX
Did you check the valve lash? Sometimes if it is too tight you'll get misfires especially on the exhaust side
Thebus1217
Jul 4, 2015 07:24 PM
Bigrome34
12
Jul 27, 2010 01:01 PM
gray89si
10
Feb 8, 2009 10:40 AM
R1SRUNS
Sep 8, 2006 03:56 PM
Ex-ITR5874
Sep 24, 2001 08:05 AM
