Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2009 honda civic 1.8L.
Old Jan 21, 2022 | 02:08 PM
Arnold2113's Avatar
Default 2009 honda civic 1.8L.
I have a 2009 honda civic and it was submerged in water a couple weeks ago. I dried everything inside and out and water got inside the gas tank so i drained and cleaned it and replace the gas pump. I can get it ti crank and it will start for 1second then die. I replaced every electrical components that was submerged with water including ECM, fuse boxes and etc.. anybody have an idea on what to check for?
Old Jan 21, 2022 | 03:20 PM
Ryanthegreat1's Avatar
Default Re: 2009 honda civic 1.8L.
Did you program the new ECU for the immobilizer?
Old Jan 21, 2022 | 04:10 PM
Arnold2113's Avatar
It was a used ecu
Old Jan 21, 2022 | 04:30 PM
New to you. The immobilizer still needs to be programmed.
Old Jan 21, 2022 | 06:08 PM
Arnold2113's Avatar
I put the old ECU back and the immobilizer is still flashing (the green key symbol). Does the immobilizer resets if the battery was dead for a couple days?
Old Jan 21, 2022 | 08:01 PM
The underdash fuse box (MICU) is also part of the immobilizer. If that was replaced the immobilizer will still need to be programmed.
Tamer_n_t
Honda Civic (2001 - 2005)
Jun 13, 2018 09:11 AM
DavidHLX
Sep 18, 2008 10:55 PM
passport1
Acura TL, RL & ZDX
May 20, 2003 04:33 PM
